like on the BX, is there such a procedure of lubing the front end?
Thank you.
is there a front strut lubrication procedure for gsa?
wonderd
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
Xantia 1.9L TD 99
Mandrake
- x 694
Simple answer - no, as the GSA doesn't have front struts - it has normal suspension cylinders (which are fully self lubricating) and double wishbone arms.
What can go wrong though is the bearings in the top arm can wear out and fail much the same way as rear suspension arm bearings in later models, and the bushes in the bottom arm can do the same. (They do last a very long time though)
Why, whats the problem you're trying to cure ?
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
wonderd
- x 94
AndersDK
From memory with my CX ownership, you must check regularly that the lower attachment balllink of the front suspension cylinder is wetted with LHM.
This is inside the rubber bellow - at the bellow small end where it is a pressfit between the cylinder rod balllink and the upper suspension arm.
How you actually check it I dont know.
But logic says you simply pour in some 10mL (1 large spoon) of LHM by the vent hose, when the car is low. Too much LHM will simply not go in, i.e. it will flow over if you try
If you remove the rubber bellow, then remember there is that little amount of lube there, which can be quite messy down over the brake discs
Anders (DK) - '90 BX16Image
- x 94
on a GS/A you wont get fluid over the brake discs,as the brakes are inboardAndersDK wrote:From memory with my CX ownership, you must check regularly that the lower attachment balllink of the front suspension cylinder is wetted with LHM.
But logic says you simply pour in some 10mL (1 large spoon) of LHM by the vent hose, when the car is low. Too much LHM will simply not go in, i.e. it will flow over if you try![]()
regards malcolm
AndersDK
FrenchLeave
