ZX Track Ctrl Ball Joints ??
sooty
Unread post by sooty »
I want to replace my Lower track control ball joints (base of strut), which one side is worn.
Can't see them listed on GSF 'Online Shop' as a single or as a kit for both sides. These have previously been changed as they have nuts and bolts, fixing them to the arm.
If they don't do them any suggestions who might in the Cardiff area.
Also which is the most common rear subframe mountings to fail, the fronts or the rears ??.
thanks
Ex 307 2.0Hdi 90 bhp 2003
Ex Grand C4 Picasso VTR+ 2008
Ex Vauxhall Insignia SRI 2.0 CDTi 2010
C4 Picasso 1.6 HDi VTR+ 2014
mpr1956
Unread post by mpr1956 »
Hi Sooty, I had to do both of my front rear subframe mounts, (That infernal knocking!!!!) and from what I read on here, they are the ones to fail most often.. or perhaps they are the ones that are noticed first) . ps changing them transformed the cars' handling for the better, and it didn't take more than a couple of hours in the driveway. As for the lower balljoints, any local motor factor should have them. Best wishes, Martin
I won't do that again
x 94
Unread post by citronut »
GSF lower ball joint(swivel) with power steering 91/98(16mm)swivel pin part No. N42418 PRICE £12.30+VATand (18mm) PIN n42419 £9.75 +VAT,and i have replaced more rear rear subframe bushes than the front rears
regards malcolm
