Hi Folks,
Just got myself a '97 Xantia 2.0 SX - Very pleased with it so far, just got one question to ask.
When it's parked and the ignition is switched off. Every now and again there is a crackling noise from the O/S front. The sort of noise you'd get when you have a loose connection on a speaker. Is this where the alarm siren is located? I tried removing Fuse 17 but the noise still continued. It is definately an electrical noise rather than a mechanical one. Does anyone have any ideas what the cause is and even better, does anyone have a solution.
Cheers
Nige
Xantia - Crackling noise
AndersDK
Have you tried provoking the sound - by lightly pressing down on the front wing of the offended side ?
What I'm after is a dry front suspension hydraulic strut cylinder, which can make this weird sound as the suspension relaxes and settles like this :
1) at the moment you leave the car, the suspension looses the load of your weight and the height raises a bit.
2) the raising height is sensed by the height corrector which then releases pressure to let car sink down to correct height
3) as the car gently sinks, the dry cylinder makes this weird sound because its binding on dry working surfaces.
Anders (DK) - '90 BX16Image
DickieG
- Monaco's youngest playboy
- x 38
Re: Xantia - Crackling noise
That's located within the N/S wing, just behind the side repeater indicator.nigelpercy wrote: Is this where the alarm siren is located?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
nigelpercy
I was almost 100% convinced it was an 'electrical' noise but at least you have given me something to look at. The other post saying the siren is in the N/S wing also disproves my theory.AndersDK wrote:Have you tried provoking the sound - by lightly pressing down on the front wing of the offended side ?
