Have been using a home made dual ramp, raised one end with a standard hydraulic garage jack 2.25T 0.13-0.38mlifting
Thinking of re-inforcing the ramp on critical points, and make it lift in a scissor action with suitable safety lock function (non-return rod sliding over notches).
Thats not the hard bit.
Would it be possible in easy terms to modify the hydraulick jack for external hyd pressure input, i.e. from a standard Cit hyd pump driven by a motor ?
I know these standard hydraulic jacks works by moving the fluid from one side of the piston to the other side, when you pump on the handle which acts on a simple piston. In addition its got a simple non-return ballbearing valve in series with the pump piston to the pressure side of the piston.
The release valve is then connected between the 2 cavities.
Practical problems are of course making up suitable fittings for connections, but thats merely doing up metric to imperial union converter pipes or hoses.
Comments please.
Summertime comes with new projects.
AndersDK
Anders (DK) - '90 BX16Image
deian
