C5 Estate rear accessory sockets
birstall
Unread post by birstall »
The rear accessory (cigarette lighter) sockets (one in the boot - one at the back of the centre console) seem to have stopped working. The front one works OK.
Wondering if it will be a fuse or a loose connection somewhere.
Probably blew a fuse from blowing up footballs with a compressor!
Can anyone confirm that it's a blown fuse?
Cheers!
Current: C5 HDI Exclusive Saloon
Past : C5 HPI Exclusive Saloon
C5 HPI Exclusive Est
Xantia 1.9TD VSX
BX 1.7 TZD
AndersDK
Unread post by AndersDK »
I have no idea on a C5.
But it certainly would be logic going for a fuse. Old time standards are red 10Amp fuse for cigarette lighter sockets.
Believe the C5 is fitted with the recent type of mini blade fuses. These are the same style - but smaller - than the blade fuses you know from your BX era.
I would not dare to to increase the fuse rating. Recent cars are designed to the limit of all components, including the electric harness.
Anders (DK) - '90 BX16Image
birstall
Thanks for that.
Just to update, checked fuses last night and it turns out to be a 15amp fuse on the second row back third from the right. I assume the higher rating is because they have two sockets working on the same fuse circuit.
Cheers.
Xantia 1.9TD VSX
BX 1.7 TZD
jeremy
Unread post by jeremy »
Some old Lucas ones used to state the continuous and peak ratings - so an apparent 'White' 35 amp fuse would also be marked 17 amp continuous. Whilst I understood the significance it always confused me when replacing one that was stated in the manufacturers handbook as being 35 amp.
jeremy
dnsey
x 19
Unread post by dnsey »
Good point!
In most cases, fuses are rated by their holding current, not rupture current: not always appreciated by users when deciding what spec they need.
