Thanks in advance
Buying a 307SW
p20
Buying a 307SW
Hi. i currently own a Xantia HDi, but its dying. So i've seen a Pug 307SW. Its an HDi110, so i know about the engine. What else should i look at when buying a 307SW. Don't need the 7 seat option, but any problems with the glass roof (which looks fantastic 8))or anything else?
Thanks in advance
Thanks in advance
307SW HDi 110
Brian UK
Read the posts about the particulate filter, and diesel additive. This might not apply to the Xantia.
Had a front wheel bearing go on mine @ 90k, cost £95 (just the bearing) from Pug dealer cos it has a magnetic sensor built in for the ABS.
Not heard of any problems with the glass roof, but then it doesn't move.
Brian.
DavidT
Also watch out for
- Flywheel issues as I had to have mine replaced @ 45k, this is a well known problem.
- Valve in Turbo also seized so had to replace @ 45k
- Paticulate filter maintenance now required @ 52k
All of the above are quite costly repairs so tread carefully. I only bought mine in Nov06.
Rgds
David
Rgds
David
p20
