Since I've had my Activa, I've had nagging doubts as to how well the Activa system is working and now I'm rapidly coming to a conclusion it is not quite as it should be
My suspicions are thus:
1. The car has a slight lean, more at the rear than the front, toward the nearside;
2. When the rear is up on axle stands, with the hydraulic system fully depressurised, the nearside rear wheel is cocked up very high, somewhere between low and normal suspension setting, whilst the offside rear wheel is right down, not far off the high setting. This can be explained by the Activa Ram being at full extension. It is very rigid and it is impossible to move the nearside wheel any further down or the offside wheel up. It is almost like the Activa Ram is stuck at full extension and cannot be moved.
I would have thought that with the hydraulics depressurised, the ram would move fairly easily. Maybe not. It is not seized arm bearings because the car responds to the height lever with all four wheels on the ground normally and when in soft mode I can push and pull the rear suspension nearly over its full travel by pushing on the boot. There are no creaks or other tell-tales that the rear arm bearings are badly worn.
3. If I repressurise the hydraulics with the suspension in low but still with the rear up in the air on stands, the front comes up when the lever is set to high but the rear will not move. The rear height corrector is clearly fooled by one wheel being up and the other down. I can only get the rear to move by jacking the rear enough to remove the axle stands and when I let the jack down, the rear bottoms out and then rises normally up to maximum height.
4. Now, with the car sitting on high, if I return the height lever to normal, the rear comes down to normal height (but leaning slightly) but the front stays at full height. The only way to get both front and rear to normal ride height is to go to low setting, allow both ends to fall and then move the lever to normal height. Both ends then come up to normal height.
Still with me
In normal use, the car sinks over to the nearside after standing the night and rapidly corrects itself to just a slight rear nearside lean on starting up.
This slight lean seems to me to be caused by the normal suspension cylinders "fighting" the Activa Ram.
The handling does not seem to be quite "right". That is all I can say and I came more to that conclusion after driving the TD Xantia this weekend for the first time in ages. It handled really nicely with little more roll than the Activa
Both hydractive electrovalves are fully functional and the anti-sink sphere is fairly recent. I cannot hear any life in the Activa electrovalve. Should it operate like the hydractive electrovalves and at the same time
When depressurised, should the Activa Rams move freely, like suspension cylinders will?
This evening, I started investigating. I can barely move the rear Activa Ram, even when jacking it or the wheels with the system depressurised. I tried to open the bleed nipple on the Activa Sphere block but no chance, It is a bit corroded and very tight and I bottled out. A sheared nipple here wild be a disaster
I have read the print off the Activa section of the Citroen Technical Guide and I have a fair understanding of how it all works.
These I see as suspects:
1. Could the roll corrector be seized, thus holding the rams fully extended?
2. Could the Activa Sphere be totally flat (it looks old) and cause this?
3. Could the electrovalve be non-functional and holding the Activa system in maximum stiffness?
None of this, except perhaps a seized roll corrector, seems to explain though, why the ram seems immovable even with the system depressurised. Surely any residual pressure should leak away with the system depressurised?
Can the rams seize?
Thanks for staying with me
