hi every one
can any one out there in citroen land tell me if it is poss.(with little cost)to get a bit more power out of my 97xantia td lx. the engine has only done 54k.
many thanks
paul
xantia power +
jonkw
Try vanaaken developments at www.vanaaken.com
They offer various performance upgrades for the 19td engine, I had work done on a ZX 19TD by them a few years ago, which took power to about 105hp from 92, and the difference was really noticable.
Andyspares Ltd
[email protected]
Andyspares Ltd
[email protected]
jonkw
Andyspares Ltd
[email protected]
Andyspares Ltd
[email protected]
rustytoba
paulcof
Hi after speaking to you vie e-mail I found out some info you might like.
If your engine is fitted with a Garret turbo then these have external waste gates and actuators. So you can obtain a bleed valve from good car accessory shops that is fitted in-line with the vacume servo attached to the waste gatre. This alows the turbo to produce more boost befor the waste gate kicks in as the vacume is restricted, prolonging the amount of time the turbo is in use and increacing power.
