C5 Instruments
bbrucez
C5 Instruments
Unread post by bbrucez »
On cold/damp mornings, sometimes all my instruments read zero.
If I switch off and restart, usually some or all of them work again. I have to keep doing this untill all of them work.
This is becoming a pain and seems to be getting worse. Are there some contacts that need cleaning?
Cheers,
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
2003 53 Smart Passion
1998S Nissan Skyline GTR VSpec
KevMayer
Unread post by KevMayer »
It sounds like a loose multiplug on the back of the instrument display.
You could try removing it and checking the connections. I think that's what I'd try first.
Kev
Cheers, Kev
bbrucez
Thanks Kev,
It's OK ATM but I'll check that out.
Is it easy to remove?
B
Cheers,
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
x 1044
Unread post by wheeler »
very easy to remove. if you look at the bottom of the panel you will see 2 dots. slide a couple of plastic levers under the panel at the dots & carefully & evenly lever the panel out. it just pops out & pushes back in.
