ABS Warnng light
mikep
ABS Warnng light
Unread post by mikep »
My P reg Xantia ABS warning light has been going on and off for months
but now it comes on the moment I touch the brakes, also getting a hell of a noise as well. The car is running ok apart from this noise.
Does this indicate a replacement ABS Controller ?
mikep
Citroen Xantia auto sx 1996
slim123
Unread post by slim123 »
Putting the ABS light on is an indication that the ABS is disabled, so I doubt if the noise will have anything to do with the ABS.
Are you sure that it's not the brake pad warning light?? it could be a simple case of pads worn out and making a row as the discs are being ruined!!
Regards
Slim.
mikep
ABS Warning Light
Thanks for your prompt reply Slim, I always understood the yellow
warning light indicated a sensor was not working, does it also double up
as a warning re brake pads ?
The noise really became bad on the way back from Calais yesterday and
if you are right they are well and truly ruined !
mikep
Brian UK
Unread post by Brian UK »
What sort of noise? A drumming/vibration means that the ABS is activating. A grinding noise means that the discs are now knackered.
ABS activating can just mean a problem with one sensor. This is the most likely cause.
Brian.
mikep
ABS Warning Light
It was more a screeching sound, like cables being stretched to limit
mikep
David W
Unread post by David W »
Mike. Please excuse me asking this but.... You're not confusing the low pad warning lamp and the ABS warning lamp. Both orange, sit side by side and even the symbols are quite similar.
When you turn on the ign but don't start the engine the ABS lamp should be lit.... but as long as you haven't got your foot on the pedal and if the handbrake is off then the pad warning lamp is not usually on a rest.
David
2009 C5 HDi VTR+Nav Tourer
2006 C3 HDi Desire
mikep
ABS Warning Light
No just checked and the brake pad warning light is on extreme left and disappears on starting, as does the ABS. But when I start driving and touch the brakes the ABS light comes on. The horrible screeching noise starts when I apply the brakes to stop.
mikep
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
It sounds to me as if the ABS has had a long running fault, now in addition the pads (either front or rear) are worn out causing the screeching noise.
Until you eliminate the pads its diffucult to diagnose any futher.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
mikep
Sorry I am a prize idiot ! only excuse is my eyesight. was reading the
warning light wrongly. It was the brake pads ( and now discs ! ) that need replacing. thanks all for help.
mikep
slim123
Thought so :lol:
Have fun!!
Regards
Slim.
TehAgent
x 6
Unread post by TehAgent »
EBay is the best place to get them from.
I went round every local supplier, the cheapest i found over the counter. was £50
On eBay, your looking at about £28 for normal disks and pads, or £44 for drilled and grooved with pads
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
Brian UK
The only problem with buying from Ebay, are the pads specially made in someone's kitchen in Taiwan? Do you really want to risk your life and others to save 20 quid?
GSF, Euro Car Parts, and NEAT all do mail order, and are relatively inexpensive.
Brian.
