Hello, I've got a LHM leak from the front strut fluid return pipe on my Xantia, On the back of the strut theres a rubber block with a rubber pipe coming out of it that widens with what looks like another rubber pipe pushed into it, it's this part that's leaking. Can this pipe be changed separate from the rubber block and if so can it just be pulled apart, also can I use any bit of pipe to replace it?
Thanks,
Fangy.
fluid return pipe leak
Stewart(oily)
- x 35
AndersDK
Should be a rubber block with molded on rubber hose. If its possible to separate it sounds like its been 'repaired' already in the past.
Its a common part : Xantia front strut cylinder leak-off pipe.
Available from GSF, Eurocarparts etc etc and of course your Citroen stealer.
approx £15 my est.
Note : its a low pressure leak-off pipe.
If you experience high pressure flow rate from this pipe, the front strut cylinder is defective and must then be replaced.
The return flow is the same pipe as the feed pipe - the one you can see at the sphere in the engine bay. I.e. the hydraulic fluid runs both ways in this pipe depending on the working condition.
approx £15 my est.
Anders (DK) - '90 BX16Image
fangy
AndersDK
mpr1956
Hi Fangy.. the new front strut cylinder leak-off pipe should be supplied with the metal retaining band, which is secured by using a special plier which "pulls" the band tight around the strut.. the band has a cutout and lip which snaps into position thereby securing the block against the hole in the strut. I manage this by using slip joint pliers and a screwdriver, but I have heard that a jubilee clip is an effective alternative to the clip if you don't mind a bodge to get you mobile again till this clip can be secured properly. This fault is such a cheap and easy fix that it is worth doing properly, really. Best wishes, Martin
I won't do that again
- x 1240
mpr1956
I hadn't thought of that Peter ! now cable ties have been mentioned, I have found that those sold by Halfords are the strongest I have ever used. I have always wondered how people on this forum have managed effective seals on cv gaiters with them, as the ones I tried always broke before sufficient tension was applied. But I was in a bind and bought some "long blue ones" and they worked so well that I have left them in place. Best stop now as endorsing H******s and going off topic could be too much !! Best wishes, Martin
fangy
Thanks for the advice.
Just received my new fluid return pipe through the post from GSF, with the clip you mentioned. Do I have to dismantle the strut to get this on or does it unclip and come apart? The cable tie option is becoming very appealing if I have to strip this damn strut.
Cheers,
Fangy.
Cheers,
Fangy.
95 Xantia VSX 1.9td, Fj1100, z-750 hardtail
bxbodger
No dismantling required- just have a clean up around the strut and then cut the steel band, the pipe will then just come away.
Mine are attached with jubilee clips, and cable ties are just as good-it's low pressure,if you use ties just don't overdo it by pulling them too tight, or the block at the base of the pipe will distort and leak.
Stewart(oily)
- x 35
I normally use the stainless plate meant to keep the block in shape and a large hose clip, I have found cable ties not to be too effective, though very good ones might be okay, I generally cut the old steel band using pliers and I have heard of folks having some success fitting the standard steel bands using pincers but have not tried it yet myself.
Stewart
Stewart
fangy
mpr1956
Hi Fangy.. I'll try to describe it as best I can... Position the rubber block and clip correctly, then - using slip joint pliers position the "upper" jaw of the pliers over the V shaped outcrop of the metal clip. I then position the side edge of a flat-bladed screwdriver where the lip of the clip snaps over to secure the whole thing. the "lower" jaw of the plier is then placed against the other side edge of the screwdriver and squeeze until the lip of the clip snaps into position. I hope you can see what I mean, as I am not sure how to post pictures !! Best wishes, Martin
fangy
mpr1956
Hi Fangy.. It makes more sense(hopefully) with a picture... Position the rubber block and clip correctly, then - using slip joint pliers position the "upper" jaw of the pliers over the V shaped outcrop of the metal clip("C" in the pic). I then position the side edge of a flat-bladed screwdriver where the lip of the clip snaps over to secure the whole thing("A"). the "lower" jaw of the plier is then placed against the other side edge of the screwdriver and squeeze until the lip of the clip snaps into position. As the clip is tightened, "D" will click onto "B" in the "first" position allowing you to make any final adjustments -then hopefully a further squeeze will both allow "D" to engage with "B" and "C" can clip over "A" due to the blade of the screwdriver holding the jaw of the plier away. As you can probably guess, I do not write technical manuals but hopefully things are a little clearer ! Best Wishes, Martin
