1.9td xantia cam belt
john alexander
Hi I 've done cam belts on other cars but how do you get the bolt down the back of the cover off, ???? regards john.
- x 8058
The easiest way is to take the turbo trunking off, or at least disconnect it from the turbo inlet stub and push it to one side.
You can just get to the bolt then with a small spanner. Not as bad as it looks. It does help if you have a very slim multiple-jointed arm and 9 inch long fingers though
- x 1432
He he he - it also helps to know that this bolt is 11mm rather than 10mm like all the others on the cambelt covers....
I think if you've got the typem of turbo pipes where they're held on by a jubilee clip, then the pipe needs to come off (7mm socket on the end of a flexi drive IIRC). If it's got the other type where the pipe bolts onto a flange on the turbo then it shouldn't need to come off. Don't ever expect to undo / refit the bolt by anything other than feel though
