Xantia V6 Fuel Leak
f00lzz
Xantia V6 Fuel Leak
Unread post by f00lzz »
The wife came home last night and reported that the car was 'stinking of petrol today' and that she seemed to be using a lot of petrol (full tank in 2 days) for her 15 miles to work and back. :roll:
When I went out for a quick look I could still see the petrol trail down the road!!! :shock:
It would appear to be spraying from the fuel filter area, halfway down the car on drivers side.. does anyone have any 'history' of such filter failures???
Cheers
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 1352
Unread post by xantia_v6 »
No experience of fuel leaks on a Xantia, but something to watch for is a fitting which has burst because of a downstream blockage (perhaps in the return line from the regulator to the tank). I have seen this on a Jag and a Merc.
f00lzz
Ok thanks for that.. will be checking it out this morming.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
f00lzz
Well that was a quick and easy fix... not the usual Xantia experience :D
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 8131
:shock:
Was that caused by corrosion or mechanical damage? Say, from a flying stone.
It is in a bit of a vulnerable spot...
f00lzz
In the picture shown, I have removed the clear plastic label, which though discoloured by fuel was completely intact so I can only assume that it wasn't 'external'. The hole was at the bottom of the filter so could have been 'settled moisture' causing the metal to corrode.... but :-k
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
