strange ticking
tka
strange ticking
Unread post by tka »
I have Xantia -96 2.0i-16v. Driven 170tkm.
There is strange ticking in left front corner ... just behind the front blinker. Yesterday I removed the left front blinker and there was a strange component. It was a red-brown cylinder with an air hoses in both ends. There was also integrated some kind of relay-switch which gives this noise. The noise is like the relay switches on-off-on-off-... The noise is not continuous but it comes very often ... couple of minutes after the engine started and the noise lasts 15-20 seconds. Nowadays here is very cold (about -30 celcius). I wonder if this is the reason for that noise.
In my opinion that strange component is some kind of air pressure switch.
Does anybody know what is that strange component and what it do in engine? How I can fix the problem?
There is also some strange sound in injection inlets just near the cylinder head; belt side. It sounds like an air hose is leaking. Does anybody know???
By the way the engine itself works well.
Thankfully
Tero
Tero
IanR
Unread post by IanR »
The hiss from the injector-rail is the fuel pressure regulator. This is normal. Also, you will hear a relay click in the black control box about 30secs after the engine has been stopped. Again this is normal.
Not sure what the red-brown cylinder is.
allmond
Unread post by allmond »
Hi Tero
This rang a bell so I did a search on "behind bumper" and came up with this link: http://www.andyspares.com/discussionfor ... IC_ID=1576
I think that's your answer.
Jamie
