Xantia interior lights
pete woods
Unread post by pete woods »
only the passenger side interior light used to come on when a door was opened now none do. the Hayne lists a relay & control unit but then fails to show them on the wiring diagram!!!
Can anyone tell me where to find then please or is it likley to be some other fault?
frankie
Unread post by frankie »
I had a problem with my interior lights caused by a blocked sunroof drain leading to a pool of water under the carpet in the passenger footwell. This covered the multiway connector and caused occasional shorts and corrosion. The interior lights would come on every time I braked.
