ZX Door seal
KEB1
ZX Door seal
Unread post by KEB1 »
Hi All,
Does anyone know if ZX door seals are available as an after market part ?
There's a chunk out of the drivers side seal on our 5 door but Citroen want £75 + VAT for a replacement !
All the best,
Kristian.
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
x 8078
Scrapyard is most likely your best bet.
If you are not too far away, I noticed A5 Salvage in Leighton Buzzard had a couple in last week.
James.UK
Unread post by James.UK »
I got one from "findapart" a couple of years ago, they sent it by post, I seem to remember it cost altogether about £25 inc postage and took me about half an hour to take the old one off and fit the new one.. :)
Make sure you tap the new one tightly into the corners or you will get an overlap where the ends meet.. Dont ask! :oops: :roll:
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
AndersDK
Unread post by AndersDK »
http://www.citroen-pr.net/catalogues/il ... 411100.gif
07 - 9023 N2 - LEFT DR WEATHERSTRIP
- 5 DOOR SALOON
- 5 DOOR ESTATE
07- 9023 N3 - RIGHT DR WEATHERSTRIP
- 5 DOOR SALOON
- 5 DOOR ESTATE
price tagged at some £120 each :evil:
Anders (DK) - '90 BX16Image
x 1238
Unread post by Peter.N. »
I picked up a new one for my XM on Ebay
mezuk04
Unread post by mezuk04 »
It would seem ebay or the scrap yard would be your best bet! And you can get a few at a time from the scrappers just incase and would probably still cost a fiver!
Volkswagen Golf 59' 1.6TD S :(
KEB1
Thanks for the suggestions, I'll see what I can find.
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
James.UK
The door seal looks to be a complex affair, :roll: but in actually it is all one piece, :) just prise one end off with a big blunt screwdriver where the joint is at the bottom, and then it's a tug-of-war job till it comes right off. :D
Refitting is a reversal of removing.. :lol: Heh heh just kidding!! :wink: :lol:
To put the new one on I lightly greased all round, then tapped it on starting where the old joint was, then just used the base of my hand to thump it into place as I worked round the door opening. if the joint is to open, or overlaps, the grease will allow you to adjust it a bit by sliding it along slightly..
When its on, spray round it with silicone to prevent it sticking to the door in cold weather.. :)
AndersDK
James.UK wrote:... When its on, spray round it with silicone to prevent it sticking to the door in cold weather.. :)
No :shock:
Instead use the small bottle with a brush in the lid :wink:
Silicone makes it near impossible to do respray jobs on paintworks, so silicone stains all over should be avoided.
