What size/type of front discs should I get for my 1996 Xantia Estate SX 2.0 16V?
I bought a pair of 283mm-24mm Bendix discs the other day, but they do not fit!
I spoke to GSF and they say that there are a number of different brake systems available for my car and I, obviously, need to find out which brake system is used.
Any suggestions on how to identify the brake system manufacturer?
Regards,
GB
Xantia Estate front discs
- x 1238
David W
In what way don't they fit?
They sound the correct fittment for your car but I thought they were 283 x 22m thick.
The 283mm discs fitted most models apart from TD auto, HDI 110 & later petrol turbos which all had 288mm dia ones.
There were two variants of the 283mm discs, thickness being the difference. The standard (which I think you need) is 22mm, and the other 26mm which fits the earlier petrol turbo and 2.1TD.
HTH
PS: In all cases I'm referring to the Estate car fittment.
David
HTH
David
2009 C5 HDi VTR+Nav Tourer
2006 C3 HDi Desire
2006 C3 HDi Desire
GB
Thanks Dave,David W wrote:In what way don't they fit?
HTH
David
Now that I know the correct discs are 22mm, I have finally identified the problem: 26mm 283mm (2.0 16V Turbo) discs supplied in a 22mm 283mm (Estate) packaging.
Thanks for everyone's help - will source the correct discs tomorrow.
Regards,
GB
05 C5 VTR 2.0 HDI
115k
115k
np
