Being a total C5 novice (in fact, total car novice), I am reading some horror stories about slipping clutches and Fly Wheels exploding.
I have only just bought my C5 2.0 HDI VTR with 60k on the clock and the clutch bite is right at the top with very little play.
Still unsure whether it is actually slipping at all as still getting use to the car.
Could this be a sign of a wearing clutch and if so should I be covered under a Car Supermarket's 3 month standard warranty?
Does 53 Plate C5 110 HDI VTR 2.0 have DMF
paulbx
Clutch clip diagnosis
I don't know if your model is DMF but a test for slipping / worn clutch is as follow.
Make sure nothing close parked in front of you
handbrake on FULL
Seatbelt on
Put car into 4th
Pull away as a if normally in 1st gear
IF car shudders quickly and violently to a stall ( head hitting windscreen) clutch is good
If it only dies after a bit of half hearted shake - clutch is worn
PaulB
handbrake on FULL
Seatbelt on
Put car into 4th
PaulB
Broomie(paulB) Xantia Hdi 90 estate
Citroen Virgin
- x 1238
Citroen Virgin
