Give it a good clean out and flush the coolant system on the engine and use it to generate some power.
Now i'm thinking of using the normal engine mounts to a metal fram and then mount that frame using some more engines mounts to some kind of steel chassis on skids.
Obviously id probably strip the engine down and build it back up using new bits and rings and the like.
This whole lot would then be encase in a larger steel case that i would then have bolted down to the skids and then have another case over that one, possibly using some roofing felt to help with sound insulation.
The engine would then run on WVO, using the cooling circuit to heat up the processing plant and thus powering itself.
Now ive worked out roughly for a small house it would need to generate about 33mw when everything is on in the house so id have to rig up some kind of load sensor that could then control the throttle on the engine.
I would use 2 radiators from a Xantia as backups that would also have a control valve on them so if the water temprature kicks in to 90' then it opens and allows the water to circulate.
Now i was thinking of using a XUD11BTE engine but the pumps on them dont seem to be as strong and then id still have to find a mechanical pump and not the electronic ones to make things a lot easier, the other advantage is parts seem easier and cheaper for the 1.9 engine
Now the idea is it would only cost me the parts, time to set it all up and then the time getting the WVO and having it all filter out and made usable.
This would be the main source of power but i would probably have some solar panels as well on a southerly facing wall and a wind turbine or two about as well so that on the days i have to drain the oil out and do a quick service on the thing then the house would still have some power to get by as i reckon an hour would suffice to remove the two shells and then drain the oil out whip the filter off and stick a new filter and new load of oil in.
Now its not feesable just yet as we would need a much bigger garden, as well as having the two shells id probably have some form of trellace(spelling) and such like with plants growing up it to help act as a sound barrier.
Anyone ever thought of this at all or got any tips/thoughts on it?
