I have a bx fitted with 165/14 tyres can anyone tell me is there another size I can fit onto the same wheel
thanks
george
Bx Tyres
soundchild
Dave Burns
If you fit wider tyre's you should reduce the profile of them accordingly to match the original wheel diameter as near as possible.
If for instance if your tyre was a 165/70/14, where 165mm is the width, 70 is the aspect ratio (percentage of width), and 14 is the rim diameter in inches.
Your overall wheel diameter would then be 586mm, you need keep within a few millimeters of the original size for the speedometer.
Dave
Dave
