Before I tackle replacing the Clutch Clip as previously discussed, am I OK using the existing auto adjust cable? Is there any different procedure other than assistant pushing at gearbox end to enable location of nipple in clip?
When I was first investigating problem I did have a bit of a pull and push on the inner cable at gearbox end. Even though I know I need to get the clutch replaced, I'm just concerned about reconnecting cable and it not allowing correct engagement, what's left, of plates.
Anyone got any advise please.
Thanks to Rory for letting me have his surplus clip.
Xantia Clutch Clip on Auto-adjust Cable
Malcolm
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
- x 94
Malcolm
- x 1238
If its the same as the XM cable, it will have a spring around the outer near the pedal end. You can release the adjustment by pulling the spring end nearest the pedal toward you as you pull the inner out. On the XM I made a tool from a straightened metal coat hanger with the end bent into a hook and slid it along the back of the engine, so I could pull on it whicle trying to hook the end on the clutch lever. Its easier with two people though!
RichG
I have done the auto adjust clutch cable a couple of times on my Xantia by myself. IIRC unhooking the cable at the clutch arm end and pushing it back into the outer gives plenty of slack at the pedal end to locate the clip.
Richard
Richard
1998 Xantia 1.9TD Estate (Sold - replaced with Skoda Octavia (sorry))
Malcolm
Thanks for that guys. My intention is to get the clip done to enable to get it into a garage for a clutch replacement, this being the root cause.
The guy in garage I called qouted me for replacing clip also. When I told him I was changing this so that I could bring it in, he didn't recommend driving it suggesting it may break again after 100 yards.
I previously mentioned that the clutch was getting heavier, different feel on operation, when I took it over to Westroen last week. With a new clip fitted what do you guys think as to reliability to get to garage - about 32 miles?
Malcolm
