Ok I will assume the plug is surplus to requirements.
I have had a diagnostic check on the car that points to a permanent fault on the nearside front. Today I removed the wheel to check the sensor and found the securing stud and nut missing along with the covering cowl that the offside seems to have, the sensor was still fixed in place tightly and I removed it to clean, I replaced it and fitted it with a bolt to secure. The ring on the driveshaft did not appear to be damaged in any way. I did notice the sensor had a metal sleeve in the bolt hole and was wondering if this needed to make an earth through the sensor?
How can I check the sensor? Is it just a matter of disconnecting the plug that comes from the sensor and connects under the bonnet and check for continuity through the sensor cable, if so what result should I get in terms of resistance?
