Xantia Regulators, Lots of em!!!!
slim123
Unread post by slim123 »
OK, Heres the question that I have been trying to find the answer for, but I am not very good on the PR NET thingy.
On the Xantia there are 4 x different regulators fitted.
1x (A) Fitted to the early type using a flow valve and without the anti sink (same as BX / XM)
1 x (B) Fitted to the anti sink models up to approx 1998. The thread size in the input hole (6.35 pipe) is the standard M12 x 1.25.
1 x (C) Fitted to the later Xantia after about 1998. The thread in the input hole (6.35mm pipe) is a finer thread and does not use the standard rubber seal, the thread in this regulator is M12 X 1 (the same as the pipe fitting in the pump)
1 x (D) Fitted to only 1 x Xantia that I have ever seen! This was on my own car, a Xantia 1.8 petrol auto 1999 reg. This car had a flexible high pressure hose from the pump to the regulator with a banjo fitting at each end. A much better system but I have never seen it on any other Xantia!
Can anybody (Anders maybe!) see on PR NET any RP numbers that may help in identifying the regulators B and C as when I get a regulator for a Xantia I usually go and see the boys at Pleiades and if in doubt they give me both and I return the one that I dont use, I have tried asking at a few dealers but they simply dont have a clue.
I am not realy bothered about regulator D as I have only seen 1 of these, has anyone else come across this one ?
Any info would be a help.
Regards
Slim
x 1430
PR.net is not all that helpful in this case, as there is only 1 picture, but...
For Mk1 Cars
*5274 16
CIRCUIT BREAKER
- EXCEPT POWER STEERING UNTIL RPO No. 06443
- BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 06894
- INJECTION XU7JP AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 06895 UNTIL RPO No. 07419
- INJECTION XU10J2 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING UNTIL RPO No. 07419
- INJECTION XU10J2 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING SINCE RPO No. 06895
- DIESEL XUD9 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING SINCE RPO No. 06895 UNTIL RPO No. 07238
- DIESEL XUD9 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06895 UNTIL RPO No. 07260
*5274 18
CIRCUIT BREAKER
- DIESEL XUD9 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07261
- INJECTION XU7JP AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 07420
- INJECTION XU10J2 AND BVA AND POWER STEERING AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07420
- INJECTION ES9J4
SEE NOTE
*5274 14
CIRCUIT BREAKER
- INJECTION XU5JP AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 07419
- INJECTION XU7JP AND BVM AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 07419
- INJECTION XU7JP4 UNTIL RPO No. 07419
- INJECTION XU10J2 AND BVM AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 06894
- INJECTION XU10J2 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06895 UNTIL RPO No. 07419
- INJECTION XU10J2 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING SINCE RPO No. 06895
- INJECTION XU10J4 AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 06748
- INJECTION XU10J4R AND W/O ACTIVE ANTI-ROLL UNTIL RPO No. 07251
- TURBO INJECTION XU10J2TE UNTIL RPO No. 07443
- DIESEL XUD9 AND BVM AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 06894
- DIESEL XUD9 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING SINCE RPO No. 06895
- DIESEL XUD9 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06895 UNTIL RPO No. 07260
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING UNTIL RPO No. 07260
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING UNTIL RPO No. 07265
- TURBO DIESEL XUD11BTE AND REGULAR AIR CONDITIONNING UNTIL RPO No. 07302
- TURBO DIESEL XUD11BTE AND WITHOUT AIR CONDITIONING UNTIL RPO No. 07443
- DIESEL TURBO XUD9SD AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING UNTIL RPO No. 07265
- DIESEL TURBO XUD9SD AND WITHOUT AIR CONDITIONING UNTIL RPO No. 07265
*95 588 682
CIRCUIT BREAKER
- POWER STEERING AND 6 SUCKERS PRESS PUMP UNTIL RPO No. 06808
*5274 19
CIRCUIT BREAKER
- INJECTION XU10J4R AND W/O ACTIVE ANTI-ROLL SINCE RPO No. 07252
- INJECTION XU10J4R AND WITH ACTIVE ANTI-ROLL SINCE RPO No. 07252
- DIESEL XUD9 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07261
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07261
- TURBO DIESEL XUD11BTE AND REGULAR AIR CONDITIONNING SINCE RPO No. 07303
- INJECTION XU7JB
- TURBO INJECTION XU10J2TE SINCE RPO No. 07444
- TURBO DIESEL XUD11BTE AND WITHOUT AIR CONDITIONING SINCE RPO No. 07444
- DIESEL TURBO XUD9SD AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING SINCE RPO No. 07266
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING AND REGULAR AIR CONDITIONNING SINCE RPO No. 07266
- INJECTION XU5JP AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 07420
- INJECTION XU7JP AND BVM AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 07420
- INJECTION XU10J2 AND BVM AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07420
- INJECTION XU7JP4 SINCE RPO No. 07420
SEE NOTE
- DIESEL TURBO XUD9SD AND WITHOUT AIR CONDITIONING SINCE RPO No. 07266
For Mk11 cars:
*5274 19
CIRCUIT BREAKER
- INJECTION XU5JP
- INJECTION XU7JP
- INJECTION XU7JB
- INJECTION XU7JP4 AND BVM
- INJECTION XU10J2
- INJECTION XU10J4R
- TURBO DIESEL XUD9TE AND BVM
- TURBO DIESEL XUD9TE AND AL4 (HP16) AND AIR CONDITIONNING
- TURBO DIESEL DW10TD
- DW10ATED TURBO DIESEL
*5274 26
CIRCUIT BREAKER
- INJECTION XU7JP4 AND AL4 (HP16)
- TURBO DIESEL XUD9TE AND AL4 (HP16) AND WITHOUT AIR CONDITIONING
*5274 18
CIRCUIT BREAKER
- INJECTION ES9J4
For reference, BVM is manual box and BVA is auto box.
Not sure that helps, mind!
:lol:
AndersDK
Unread post by AndersDK »
Gosh -
Thanks RichardW, you saved me quite some copying, pasting & editing there :lol:
(I've done some minor editing to your posting, as you got tired removing extra blanks & lineshifts :wink: )
Anders (DK) - '90 BX16Image
slim123
Thanks for that, but this dont realy give any clue as to what car has the std M12X1.25 thread and what one uses the M12X1 thread.
I did find this list on PRNET but it does not state that all Xantia's up untill a certain RP no use 1 x regulator and all since use the later type. There must be a cut off point somewhere?
The clue I think is in the high pressure pipe pages, the early pipe uses the standard citroen 6.35 rubber seal set up in the regulator (used in all models since the DS) and the later one uses the M12 X 1 thread on the fitting with a small black plastic coated metal seal.
I will see if I can find a photo to post.
Any more ideas?
Regards
Slim
slim123
Here is a couple of piccys, just in case it makes it easier to understand.
Picture 1 is the standard Citroen 6.35 pipe end using the rubber seal and the M12 X 1.25 threaded fitting, the one that we all know and love.
Picture 2 is the modern type of pipe end, this fitting is M12 X 1 the same as used in the pump end of the pipe, note that the rubber seal has been replaced with a metal seal, but there is a small "O" ring bonded to the end.
Pictures would have been clearer if I was better with a camera. :roll:
Regards
Slim.
Mandrake
x 694
Re: Xantia Regulators, Lots of em!!!!
Unread post by Mandrake »
slim123 wrote:1 x (D) Fitted to only 1 x Xantia that I have ever seen! This was on my own car, a Xantia 1.8 petrol auto 1999 reg. This car had a flexible high pressure hose from the pump to the regulator with a banjo fitting at each end. A much better system but I have never seen it on any other Xantia!
Never seen or heard of anything like that either. Are you sure that wasn't just a crafty repair done by someone ? (Eg a fully custom pipe) Or are you saying the actual fittings on the pump and regulator were different too ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
philhoward
Unread post by philhoward »
That sounds like the car was owned by someone who's mate has a van with "Pirtek" on the side...
slim123
Nope!!
The car in question was a 1999 "T" plate Xantia 1.8 16 valve automatic. definatly not tampered with, as I bought the car new.
Regards
Slim
slim123
So looking through the list of numbers that Richard very kindly posted, what part No will fit the Xantia HDI? As this will give some kind of a clue, as the HDI uses the finer threaded (M12 X 1) regulator.
Regards
Slim
AndersDK
slim123 wrote:So looking through the list of numbers that Richard very kindly posted, what part No will fit the Xantia HDI? As this will give some kind of a clue, as the HDI uses the finer threaded (M12 X 1) regulator.
Regards
Slim
That would exclusively be Xantia series 2 ('98 on) models with a HDI engine.
That leaves part no 5274 19 as the only correct type as pr the list above:
*5274 19
CIRCUIT BREAKER
- INJECTION XU5JP
- INJECTION XU7JP
- INJECTION XU7JB
- INJECTION XU10J2
- INJECTION XU10J4R
DW10 designations are the HDI diesels, while XUD designations are the old style diesels.
