Firstly the presence of water diesel fuel light. This only comes on briefly and only very occasionally but any idea what causes this and what to check?
I have a Haynes manual but couldn't see any reference as to what to do.
Secondly (and a lot more regularly) I'm getting the hydraulic pressure and STOP light. I'll check the LHM levels at the weekend (don't need to drive the car before then) but is there anything else I need to check?
My Citroen manual helpfully tells me to stop driving and contact Citoen
As background the car has had lumpy idle/white smoke problems that I've been trying to eradicate so I've done the following recently.
New Glow plugs (that was fun
New fuel filter+ housing + primer bulb+ pipe between them.
New injector leak off pipes
Don't know if I've made a mess of those jobs somehow and allowed water into the system?
As information I am by no means an expert mechanic so please bear with me if I ask some stupid questions such as "what's one of them then?" in response to any suggestions. I do however have a (sometimes helpful) Haynes manual and a willingness to give anything a go.
Finally the ride at the front has always but very harsh (to the point of bouncing up and down like a pimp mobile when going over bumpy roads) which I put down to being possibly spheres but would fluid problems also be a cause of this?
