Yesterday morning I hit a large pothole (in the dark) with my nearside front wheel. It was so bad that it just about shook my fillings out. Anyway since then there has been a wheel wobble at low speeds which I reckon on checking is simply the wheel being now bent. Much more worrying is that there is a funny noise almost like two parts vibrating together on the overrun. I had a look last night and could not find anything other than the wheel being slightly out of true. Has anyone any ideas what the cause of the noise might be? I wonder if the jarring has broken an engine mount or the like but I really just don't know and am looking for any ideas.
Cheers
Dave
Pot hole damage
First choice would be to pop the spare on and test drive, if the noise stops, then its new wheel and tyre.
I would suggest the if it has done enough damage to buckle the wheel, then the tyre casing will be damaged, even if it looks ok.
Whilst the wheel is off, check the lower arm for signs of clean bits! this would suggest a bend.
A simple but not 100% acurate would be to measure from the center of the hub to a fixed point on the car, do this on the good side, them compare with the "bad " side, see if there is any difference.
Regards
Slim.
Regards
Slim.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
You'll want to contact your insurers also with a view to getting compensation from your council highways dept, and get some photos of the hole you hit.
Lexia ponce
Lexia ponce
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I second that, you need to contact the council and make a claim for malfeasance, pop your spare on and see how it drives, with a Xantia the lower wishbone or its mounting bolts might be bent as could the track rod/end.
Stewart
Stewart
Same thing happened to me - vehicle in front swerved violently at the
last moment and whilst I was trying to work out what he was up to I hit
what was practically a missing manhole cover area about 3-4" deep.
When I went back to measure and photograph the crater later it was
fixed too!
Damn it, if it's that easy to fix, why leave it there to ambush people
- there must be a criticality index that see's which one get's fixed first
- this one nearly casued the Xantia to crash off the road when the steering
got yanked out of my grip - ruined the wheel and tyre - I'm not 100%
sure if the arm bushes or track rod have had it as the steering doesn't
feel "right" though I may be being neurotic...
I believe the main culprit for this additional blight on the roads ON TOP
of all the other crap, is the Laissez Faire attitude of the cowboy navvies
operating under Utility Company colours...
Biggest measured pothole in the UK was not far from me here in South
Wales - it was so bad the local 'free-range' sheep were sheltering IN it
to get out of the bad weather...
No wonder there's more and more of those damned 4x4's with their
stupid knobbly wheels...
Andrew
fixed too!
Andrew
As an update, last night I noticed that the tyre on this side was looking a bit soft and when I checked it it was down to 16lbs. I pumped it up to the 35 requied and heard a hissing noise. When I removed the wheel and inspected it properly there is a huge dent on the inside (how did I miss that you ask) which was allowing air to escape. Fitted the spare and lo an behold everything is now fine. I guess now its have a go at the council time, but the real mystery to me is why the noise problem only happened on the overrun. Ah well, thanks to all who replied.
Chees
Dave
Chees
Dave
