multimeter setting
tanto
multimeter setting
Unread post by tanto »
hi guys
how do you use a multimeter to check the abs sensors i need to know what to set the meter to and where do i check it from for the car in sig
thanks
1996 xantia sx 2.0L 16v
if at first you don`t succeed get a bigger hammer
shaker
Unread post by shaker »
Tanto,
see http://www.frenchcarforum.co.uk/forum/v ... hp?t=20837
posted by alan s in the common problems & fixes section.
jeremy
Unread post by jeremy »
The object is to pass a small current through it - so you are checking its resistance. Use the lowest scale then go up. The correct reading should be about 900 ohms. Don't use the very high scales - you could end up measuring the resistance of your hand - which is a completely harmless but entirely useless experience which may confuse you.
Connect the 2 leads together - gives no resistance - so you should get a reading on 0 or more likely 1 unless you get a really good connection.
I'm not sure where you are measuring - but if you have the sensor connector in your hand you measure between the 2 plug pins - if its like the BX its a co-ax plug rather like a TV aerial - in which case the terminals are the centre pin and the outer screen.
Often its the lead which fails either through flexing or corrosion of the screen due to the outer insulation becoming porous. If this has happened you may be able to repair it if you are handy with a soldering iron and use a co-ax cable with a flexible centre core. (TV aerial cable with a single centre core will NOT do.) To find the problem - cut the wire at a likely spot and measure again - and keep going towards the sensor.
I found 3 failed ones on my BX when I got it!
jeremy
x 1238
Unread post by Peter.N. »
0 = full scale deflection on an analogue meter. 50 ohm amateur radio cable with a stranded centre conductor is fairly durable.
