It now has around 160K on it and has been a good car all round until she takes it to her local "specialist" who is an old plonker who should have retired a decade ago, but instead, he keeps on stuffing around and I get the impression that he seems to do things that causes her to have to go back for more work and this is an ongoing saga.
Latest is that he fitted a cambelt for her. The job went like this:- Fit cambelt charge out job, customer goes back concerned about the noise; he has the car for a day or so and returns it telling her it's all fixed. A few days later she returns it with the same noise, he has it again and when returned, he tells her he has replaced the tensioner. A few days later, she again returns and he has it again, this time claiming to have fitted a water pump.
Again she returns, this time upon completion, being told the cambelt was incompatable and a new belt was fitted. Next trip he claimed the genuine pump he had fitted was faulty so he fitted a non genuine which he charged an extra A$60 for it.
As the noise was still there, he suggested she sees if she can see a car she might like, get the engine hot on the BX and trade it in. So far, in excess of $1500 has been spent on what originally was supposed to be a cambelt change for which he quoted around A$300 because he gives this great tale whenever he has the car there always blaming parts, or whatever comes to mind and another bill is presented.
The last time she had it there, he told her he had "adjusted the timing" which on a Tri I would imagine would be no mean feat.
My problem is that I am now saddled with the job of sorting this ****ing mess, so see if anyone can make some suggestions.
Noise: When cold, there is fast tapping knocking noise that is too fast to be a con rod bearing; sounds more like something rotating. It seems to eminate from cylinders 3 or 4 and comes from partway down. Cannot be heard via a stethoscope and is constant with the pulsing of the fuel injectors. He had stuffed around with the mixture adjustment as well as the TPS and after I readjusted these close to where they should be, the rattle almost disappeared. During his stuffing around, he finished with the idle dropping back to around 400 rpm on decelleration if the engine was revved. The noise is most noticeable on acceleration from idle to around 1200 but for only a ciouple of seconds; it's not a constant.
The plugs were dry and showed all the signs of being healthy if not slightly lean on the mixture. I cleaned and refitted them.
There seems to be a slight hesitation on acceleration and the performance id "doughy" to say the least. Compared to my Tri - 122 which has similar mechanicals and is also auto, it wouldn't hold a candle to it. It just feels like an old carby distributor car that is retarded to buggery.
The auto transmission had around 1 litre+ too much ATF in it as it was about an inch above the max mark on the dipstick and draining and refilling to the correct level helped the performance and gearchanges a bit, but still in my estimation, it is still only going at around 80% of what it should.
Any suggestions (if you haven't been bored and fallen asleep reading this long winded post)
All or any suggestions gratefully accepted as she needs to be heading off home within 48 hours and I would like to get it sorted as she has 400 klms to go to get there.
Alan S
