Immob
AndersDK
Errr...
Ross, I believe the immobiliser is there for one single reason : to completely immobilise the car if messed with. What makes you think you will have more luck than a lowlifer
Please note : any information on this will have to be mailed directly to you, and NOT showed here in print - as that would make certain persons life a bit TOO easy - wouldnt it
Anders (DK) - '90 BX16Image
PowerLee
Its a diesel, the immobiliser is a right swine to try to bypass when the pump is attached to the engine & still in the car.AndersDK wrote:Errr...
Ross, I believe the immobiliser is there for one single reason : to completely immobilise the car if messed with. What makes you think you will have more luck than a lowlifer![]()
If the engine & pump are out of the car on the floor its easy
