A couple of weeks ago some little ####ard wrecked my drivers side wing mirror, I've just got a replacement through the post and want to know how easy/difficult it is.
Never had to replace one before and haynes manual is useless.
Do I need special tools etc
Replacing complete wing mirror
Saw Doc Fan
'94 M Reg Xantia 1.9 TD LX...70,000 miles, had it 2 years now and still LOVE it.
What a day,Oh what a day...
- x 1238
If its the same as the XM its screwed in from behind the outer door skin, look behind and you should see the screws, I think they are torqx. If its electric, you will have to take the door panel off to gain access to the wires, unless you fancy cutting and joining them - I did that with the temperature sensor in the n/s mirror.
AndersDK
OUTSIDE REAR VIEW MIRROR DRIVER SIDE - RETRO EXT CONDUCTEUR NON CHAUFFANT CDE MANUELLE ET CONDUITE A DROITE SAUF COQUILLE RETRO COULEUR CAISSE
http://www.citroen-pr.net/catalogues/il ... 42055A.gif
- yes it says drivers side mirror for RHD cars. But thats how its showing on PRnet ...
Anders (DK) - '90 BX16Image
dan_the_v8man
is yours the electric or manually adjusted one?
replaced my manual and it really was a piece of cake, half an hour at the most, longest part is getting the door trim off and remebering how it goes back together,
all u need as mentioned before, a set of torx bits, and a big flat tool for pryin the trim off
Dec 94 Xantia LX 1.9 TD 116k - My first car
Saw Doc Fan
