206 power steerig fluid
lawns
x 3
Unread post by lawns »
Hi all,
I am trying to find a retail supplier of Total fluide AT42 to top up my power steering as per peugeot recommended lubricants. My local Total filling stations and Peugeot dealer do not stock it ! an anyone help?
My dealer say they use Motaquip ATF type D11 but from what I can find out this is not the same spec as AT42.
Regards,
lawns.
Lincoln. UK
206 1.4 HDI SW
PowerLee
Unread post by PowerLee »
Motaquip is part of the PSA Peugeot / Citroen group so I can see why the dealer said they use Motaquip.
If a Peugeot dealer says its the correct fluid for the application then I would go with it :wink:
Why does it need topping up in the first place? PAS fluid should never need topping unless theres a leak.
pugxpert
Unread post by pugxpert »
just stick some auto trans fluid dextron 11 in it will be ok
EP6T petrol turbo nice engine in the 207 GT and the new mini....
504
Unread post by 504 »
AT42 is Dextron III specification. Do not mix this with D II. The III fluid is synthetic, and II is mineral.
Dextron III can be bought in most car stores.
