Hi all,
I am unable to log on to pr-net after years of use. I get the message that my logon or password is incorrect so I re-registerd but get the same
message with my new log on and password.
Is/has anyone had the same problem and who can I contact to resolve this?
I would also like to thank Andy S again for resolving a similar problem with frenchcarforum.
Regards,
lawns
Lincolnshire. UK
Xantia HDI 110
BX 19 Manual & Auto
206 1.4 HDI SW
citroen pr-net
PowerLee
- x 94
AndersDK
Had the same problem a year ago.
I just re-registered ** using the same username **, received a new password, then changed my account back to the old password after registering.
Have you tried the "forgot your password" option ?
Remember that passwords are caps sensitive.
NOTE : Since then I've noticed you can no longer register as a new PR-net member not supplying a company tax registration number. That was possible when I first registered.
EDIT : I'm using Microsoft IExplorer 6
Anders (DK) - '90 BX16Image
rossnunn
SteveG
vanny
handyman
I use Citroen-pr.net regularly but find it can sometimes be temperamental and exasperating, especially when it locks up on a particular icon or refuses to release information. I do not think the programme is particularly user friendly, so it must be even more exasperating for Citroen dealers and parts suppliers. Otherwise it is a good source for information.
I have never had a problem accessing it, I suppose having registered as an independent trader has helped. The ID and password information is case sensitive, so it helps to get it right every time. The only other critisism is that it is so slow when it is searching the database!
handyman
handyman
Clogzz
- x 40
MattG
Clogzz
- x 40
I got in, from Australia, which isn’t listed.
It’s all European countries and Argentina.
So, tell yourself; and tell PR-Net that you’re in one of those countries of your choice, and answer the questions to their requirements, as I did.
Anders
posts about needing a company tax registration number.
I doubt that there would be a standardised numbering system for all those countries.
So try, say, an Australian ABN number to see what it makes of it.
There are enough of them here everywhere to know what they’re meant to look like.
Anders
posts about needing a company tax registration number.I doubt that there would be a standardised numbering system for all those countries.
2002 C5 2.0i AL4 239,000 km 76372389
AndersDK
I just found out that using the help button when on the registering page, you get info on default settings, if you dont have tax reg or fax number (required !). This will enable you to registerClogzz wrote:I got in, from Australia, which isn’t listed.
So, tell yourself; and tell PR-Net that you’re in one of those countries of your choice, and answer the questions to their requirements, as I did.![]()
Andersposts about needing a company tax registration number.
MattG
