Haynes Manual
Bumble
Haynes Manual
Unread post by Bumble »
I have a 2000 V reg Xantia. Is the Hayne's manual published OK as it only goes up to 1998.
jmd
Unread post by jmd »
It is pretty much O.K,as with a 2000 car you hopefully will not be doing any major work.The haynes manual is to my mind not as thorough on the Xantia,as on other brands of cars.The big problem that I find with Haynes is that it advises you to strip so much material to carry out small repairs,and you do not need to do this in practice,yet I would not be without a copy
nick
Unread post by nick »
The only other problem you may have is if your car has an HDi diesel engine (or for that matter, a V6 petrol), which this manual doesn't cover unfortunately.
Nick
Edited by - nick on 04 Jan 2003 18:14:42
