Xantia front suspension - changing silent blocs
lolingram
RIP 2010
Unread post by lolingram »
Anyone know if the old silentlblocs need a press to remove them from the wishbones?
Cheers
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
jeremy
Unread post by jeremy »
You can remove them without a press by sawing through from the centre to the outside to cut the outer steel ring and relieve the tension on it. Some grease on the hacksaw blade as it goes through the rubber bit helps.
They will then drive out quite easily unless completely rusted in.
jeremy
f00lzz
Unread post by f00lzz »
jeremy wrote:You can remove them without a press by sawing through from the centre to the outside to cut the outer steel ring and relieve the tension on it. Some grease on the hacksaw blade as it goes through the rubber bit helps.
The best lubricant for rubber is ..... water!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 94
Unread post by citronut »
i usualy just drift them out with an impact socket,then use my old fix or rust daily(f**d) void bush tool to refit them,also the bush with the flandge just raise the edge all the way around with a small cole chissel so it will pass through the eye in the arm
regards malcolm
