Does the airbag need to work for the car to pass the MOT? Or is it an advisory?
airbag light and MOT
- x 94
np
SteveG
np
PowerLee
A Xantia wont have a warning beep sound for the airbag fault.deian wrote:a buzzer too? why where when?
A multiplexed car will though, dash warning light will come on, warning message up on the display & a lovely BEEP BEEP BEEP from the COM2000
Does the same for ABS faults too ( I was having a play
np
PowerLee
I like it when it has 2 or 3 messages to show you, or you open the door & shut it again & it starts scrolling through.np wrote:Thats right Powerlee.For the others,the 406 has a central display,with MPG,trip,out side temp,time & date,sat nav.It also displays warnings,like "airbag defective",& "fuel level low" when the gauge light comes on.Also "door open" etc.
Ive had up at different times so far on the 206.
ICE ALERT
FUEL LEVEL LOW
ENGINE IMMOBILISER FAULT
ABS FAULT
AUTOMATIC WIPING ACTIVE
AUTOMATIC HEADLAMPS ACTIVE
PASSENGER AIRBAG DEACTIVATED
Also has the pretty picture of the car & what door / boot / bonnet is open
