Part number needed
deian
Part number needed
Unread post by deian »
Hi guys,
I've been on Citroen-pr.net but I still can't find the part I'm after. So can anyone else have a look for me? Much appreciated, it's:
The auto tensioning pulley for the auxilary belt, after 200k miles it is bound to need replacing, it's squeeks like hell at the moment so i think it's time to change it along with the belt.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The GSF catalogue has the relevant part numbers in it, to fully recon the tensioner you need th pulley and its pivoting mounting and the spring assembly which fits behind the HP and fuel pumps, the catalogue does mention supplying the parts together.
Stewart
deian
Sorry stewart, I'm non the wiser. I am looking for an automatic tensioner pully for the auxilary belt for a 1998 2.1td WITH Aircon, I can't see it in GSF! I see ribbed belt.
AndersDK
Unread post by AndersDK »
Look carefully on the schematic submitted below. This is for a 4-point fixing alternator.
If your Xantia setup does not look like the schematic - then the parts list submitted below CAN NOT be used.
Otherwise the parts list and schematic is valid for all series II Xantia XUD variants with A/C.
http://www.citroen-pr.net/catalogues/il ... 32051A.gif
Xantia II
0291 02 532051A ALTERNATOR AND FIXINGS DIESEL XU ET REFRIGERATION
7/13/2006 2 ALTERNATOR AND FIXINGS 0291 02 5320 51A
NOTE : FOR ASSEMBLY ALTERNATOR 4 POINTS AND COMPRESSOR SANDEN OR DELPHI HARRISON
- DIESEL XU AND AIR CONDITIONNING
02
5706 D4
ALT BRACKET
03
5751 30
TENSION ROLLER
04
(4010 23)
4010 74
PLAIN WASHER
05
5751 81
TENSIONNER
- DIESEL XU AND BVM AND AIR CONDITIONNING
- DIESEL XU AND BVA AL4 AND AIR CONDITIONNING
06
5703 92
NUT WITH BASE
07
5751 29
TENSION ROLLER
20
5750 M7
DRIVE BELT
"WITH SANDEN COMPRESSOR"
20
5750 Z5
DRIVE BELT
"WITH HARRISSOW COMPRESSOR"
21
(5751 58 )
5751 24
ROLLER
- DIESEL XU AND AIR CONDITIONNING AND BVA AL4
Anders (DK) - '90 BX16Image
deian
I think you may have found it Anders, not 100 sure but the roller looks about the same size and t is close to the alternator, you are a credit to the forum, imagine how long it would have taken me to find that... forever!
Now what do i need altogether? a new belt obviously, i think items 7, 3 and 5?
It's a VERY tight squeeze between the pulleys/belt/engine and the side of the chassis, i reckon 15mm! Maybe if i work from the bottom with the wheel and plastic guard off it'd be easier. I will probably post about the job at a later date.
Thanks Anders, nice try mr oily, much appreciated.
