Airbag light won't go out
genius149
Unread post by genius149 »
I'm sure there's probably a thread on how to do this already but I can't be assed to search for it. :D
The light for the airbag in the seat is constantly lit in my other half's '00 Xantia Activa. I saw a solution in the Lexus forums, but Japan and France are miles apart (Soarer Active aside).
Can anyone help???
XM 2.5TD Exclusive - now deceased :(
Hand-me-down Xantia TD SX (killed)
Wife - 2000 Activa (sold)
2000 Xantia 1.8 16v DualFuel (killed/sold)
Current - '99 S2 Activa +Leather+winter pack
PowerLee
Unread post by PowerLee »
Either a dodgy connection under the seat.
Or it could be the metal safety clip on the back of the side airbag has tripped because the connector plug is slightly lose on the back of the airbag so it puts the warning light on.
Without a fault code scanned from the SRS ECU you aint gonna know what it is.
howzat
Unread post by howzat »
Disconnect battery, wait 30 mins, disconnect yellow plugs under seats and squirt with switch cleaner, reassemble. I find this works but has to be repeated from time to time.
PowerLee
With seat mounted side airbags the metal safety clip on the back of the connector plug on the airbag inside the seat is always worth a look / press back in :wink:
