Xsara door handles keep snapping????
talbotsteve
Unread post by talbotsteve »
Mate of mine has a 5 door xsara and has managed to break both door handles off on the drivers side????
anyone know if this is a common problem and where i can get another pair, also are they sided or common to both sides of the car?
cheers
steve
x 94
Unread post by citronut »
quite often this i down to the lock mechanisum being dry and binnding,so you need more force on the handle to open the door
regards malcolm
omriohyon
Known problem
Unread post by omriohyon »
this is a known Xsara problem
i alredy relplaced 5 on the last 7 years.
Try to open them UPWARDS, using your hand upwards, and not just pull it.
it helps.
it always happen after rain
