My Sister says "Will you change the glow plugs in my car over Christmas" (ZX 1.9D). I say "No, bother, should be piece of cake" (Have done the Xantia and ZX TDs recently). So off we go on Boxing Day - quick look under the bonnet reveals a Lucas pump and 3 easy plugs, with one a bit tricky behind the injector pipes. "Game on" I think, be back in the warm enjoying the beer in an hour. Get the wire off, and then a deep socket on no 3 plug. Hmm, she's a bit tight (all the other ones I have done, the plugs have been finger loose after breaking the initial seal). Then after about 1.5 turns CRACK - a big lump falls off the cylinder head
I wasn't thinking game on any more - more like new head time
On the up side the plug then screwed out easily - but revealed the top 3 threads to be missing, presumably rusted into the head and stripped - I doubt we'd have got this out without busting the head any which way. Undeterred (well not much) we checked that the new plug would screw in and tighten up (about 40% of the thread remained). and then got the others out. We were a bit more careful, using easing spray and going in and out, but even so 2 of the 3 were tight and needed spannering all the way out (and the new ones in). Only No1 at the flywheel came out and went in as expected with fingers only. It looked like the plugs (Bosch) had not fitted in the threads very well, and the head was a bit mashed - no evidence really though that they had been changed before (it's a 94 car with 94k miles). No 3 was refitted with red loctitie and then a good mound of chemical metal around it. It has so far survived my Dad ragging it at the red line and then the 300 mile trip home with no apparent ills. Looks a woeful bodge though
So, moral of this story.... if the plug is at all tight go VERY steady. Unless you like changing heads for fun (I don't)!
Don't suppose my Sis will ask again.....
"It just came off in my hand guvnor..."
"Does it say 'Rebuilds cylinder heads' on the packet?"
