Well,touch wood i`ve not had the warning beep & light come on for 3 days now,touching wood
.Maybe its sorted its self.Back to work tomorrow so will be doing more miles so will see what happens.
Got the new year door seal,£58
,but it seems it still alowing water in.Its better,but still leaking.Looking at it,water is coming out of the drain hole on the bottom of the rear pass door,& in over the top of the seal.It only started doing this a week or so after i got the car.The door dos`nt sag when open,& its all a tight fit when closed,so nothing has changed.I may try to cut a bit of the rubber off the seal at the door drain hole to see if that cures it.Other than that,i`m a bit stumped
