Height adjustment is all messed up. Can you point me to where I can get info on how to adjust it? or at least whats the correct height?
thanks
the linkage is pretty well lubricated by 27 years of oil leaks and yes,Peter.N. wrote:'Correct' height is usually when the suspension arms are parallel to the ground. I think the height adjusters are similar to the CX ones, which in turn are similar to the modern ones, in which case, lubrication of the linkage is the first port of call, unless you know that the height setting has been interfered with.
What clamp? the one one the antiroll bar or another one?FrenchLeave wrote:
Then, Front: slightly slacken the clamp of the automatic control, adjust the clamp to give correct setting and retighten to 0.8 - 0.9 kgm (5.8 - 6.5 lb.ft.) .
ther clamp which is mentioned is the adjuster clamp on the antiroll bar,sounds like the one you have adjusted on the front end,this is the same at the rear,which you can not get to from the top,the linkage which is visable from the inspection panel in the boot floor is the hight corector linkage which should not be adjusted to alter the ride hightekaftan wrote:What clamp? the one one the antiroll bar or another one?FrenchLeave wrote:
I did manage to adjust it an hour ago. what I did was to slacken the roll bar clamp, raise the car fully, tighten half way the clamp, lower the car and then with a large flat screwdriver managed to move the clamp until the height was ok, then tighten.
I never got the space to rotate it towards rising as it was too stiff.
Thanks for the instructions on the back one. It was ok so I did not mess with it
Huh ?citronut wrote: ther clamp which is mentioned is the adjuster clamp on the antiroll bar,sounds like the one you have adjusted on the front end,this is the same at the rear,which you can not get to from the top,the linkage which is visable from the inspection panel in the boot floor is the hight corector linkage which should not be adjusted to alter the ride hight
regards malcolm
ps.
the mesurements i posted are from the genuine citroen manual
HAPPY NEW YEAR TO ALL
Hi Malcolm,citronut wrote:ok Simon
it seems you are wright on the rear hight adjustment,but it seems you loosen the rear H/C mounting bolts and slide it forwads or backwards to acheve the corect hight,as the other adjusters are not realy for fine adjustment ,but for adjuting the manual hight contl setting,because when the car is set at the normal ride hight the front and rear hight corector links should not be touching the manual adjuster rod coupleings,as they should be free floatting
regards malcolm
ps.
HAPPY NEW YEAR
