Now I've cured one of my cars two annoying traits (the lurchy throttle) I thought I'd approach the other one in a different way.
The car sinks quite soon after the engine is turned off (it's not anti sink, and yes I've changed the accumulator, LHM, filters etc and reseated the non return valve in the regulator). The regulator clicks every 8 seconds.
I've noticed several things that become normal if I apply the brakes...
Holding down the brake pedal hard (I mean standing on it), the regulator starts cycling every 30 secs,
If I turn off the engine, after 30 secs the front suspension starts to creak and slowly drop. If I pump the brake a couple of times and hold it it stops the suspension dropping. On releasing the brake...you've got it...she starts to sink again.
Finally, if I traced the correct return pipe, the one from the brake valve when removed sprayed my garage wall with LHM with the engine idling and pedal released.
Chew that one over chaps
regards
davetd
