Hi
the centre two injectors on my 1.9TD appear to be leaking. they have being doing it for a while now. it isnt a major leak and it isnt dripping but its more than a weep. i wiped them clean and after a few hundred miles they were in the same state again
it would appear to be oil that is leaking. it doesnt smell like diesel, but i have had a fair bit of bio in the tank.
any idea of the cause, solution or if i should even be worrying about it?
once again, thank you all for your help
Dan
xantia leaky injectors
dan_the_v8man
Dec 94 Xantia LX 1.9 TD 116k - My first car
- x 8078
Sounds at first like your leakoff pipes may be leaking Dan. These are the little black pipes daisy-chained between the injectors. But if you are not experiencing starting problems then it is likely they're not..
The oil you see is actually from the turbo trunking joint above the rocker box. However carefully you try to do them they always weep a bit of oil which drips and covers the two centre injectors and makes a little puddle in one of the centre head bolts. The oil you see is condensed oil mist from the crankcase breather and it is under turbo boost pressure.
Totally normal. Nothing to worry about at all!
But do check your leakoff pipes and if you have any doubt about them, replace them.
jeremy
dan_the_v8man
dan_the_v8man
