Hi
the priming bulb on my 94 xantia 1.9td has got lucas written all over it. does the bosch pump use the lucase priming bulb as i was certain my fuel pump was the bosch pump
cheers
Dan
xantia td fuel pump priming bulb
dan_the_v8man
Dec 94 Xantia LX 1.9 TD 116k - My first car
AndersDK
dan_the_v8man
- x 8072
Very unlikely on a TD. Most had the Bosch Pump.
Easiest way to tell is to eyeball the pump. If it has a "Flying Saucer" on the top of it with a pipe going off from the top of the "Flying Saucer" to the "hot" turbo trunking then it's a Bosch pump.
Lucas pumps are normall flat at the top.
