Belt tension
JohnD
- x 72
Belt tension
Autodata quote belt tension in SEEM units but I've bought on eBay a Burroughs BT33 gauge which is scaled in Newtons. Has anyone got a conversion table?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Clogzz
- x 40
Possibly somewhere in here,
though I can’t see it:
http://www.onlineconversion.com/force.htm
http://www.onlineconversion.com/torque.htm
http://hemsidor.torget.se/users/b/bohjo ... htm#torque
2002 C5 2.0i AL4 239,000 km 76372389
alan s
- RIP 2010
- x 6
Don't like your chances; "Seems" is a "proprietary" (sp) measurement and is based on the same principal as tuning a geetar or violin/fiddle and I could imagine that info would be about as easily obtained as Blair or Bush's after hours phone number.
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
jeremy
Kowalski
Re: Belt tension
Can you use your gauge to measure the tension of the existing belt before you remove it?JohnD wrote:Autodata quote belt tension in SEEM units but I've bought on eBay a Burroughs BT33 gauge which is scaled in Newtons. Has anyone got a conversion table?
That will give you an idea of what tension you're looking for with the new belt, but bear in mind, the tension on the new belt should be slightly higher than the old, since the new belt will need to bed in and will lose some tension while that happens.
bxbodger
According to this-http://www.honestjohn.co.uk/forum/post/ ... =i&t=18875 45 seem units = 240 newtons although I don't suppose anyone outside of an official main dealer franchise would use such a unit!!
Hopefully 1 seem then equals 5.33 newtons........
I've never actually measured a belt tension-I just crack the tensioner on until it's hard to push the belt by thumb on its longest run...after all, it's not going to get any tighter by itself, only slightly slacker which the tensioner will take up anyway.
AndersDK
SEEM units are in no way a standard "unit" - other than when using the mentioned SEEM manufactured tool.
AutoData offers this document which provides a comparison table for the different units :
http://www.autodata-online.com/uk/tbinfo.pdf
Here you can see that Burroughs and Sykes-Pickavant are the only tools calibrated in standard (but different) ISO units.
SEEM offers 2 different tools - NOT calibrated in the same units
Its pretty much like manufacturing an "AndersDK" gauge tool - which offers the readout calibrated in "AndersDK" units
Then later introducing "AndersDK-Mk2" tool - calibrated in "AndersDK-Mk2" units
Anders (DK) - '90 BX16Image
JohnD
- x 72
- x 94
bxbodger
Thatas quite bizarre
- looking through that comparison chart it appears that Burroughs do a standard gauge,calibrated in newtons, and also do the same gauge, but for Rover, calibrated in some strange Rover units.....and Ford, VW, etc, also have their own units of measurement
Imagine what it would be like if they all introduced their own version of torque measurements-I wouldn't put it past them to do it as a way of preventing home servicing.
I'm sticking with the thumb test!!
David W
I provided the data linked to on that Honestjohn post. The conversion of Seem - Newtons was given at a specific point and is not linear throughout the range. And as commented above the different Seem testers give slightly different results.
So to get a conversion you need to look up the comparison at the particular figure for your car and not do the maths worked from another point in the range.
Thank goodnes my thumb is calibrated to check the gauge is correct!
David
David
slim123
David W
Actually we are lucky with Citroens because they have some of the most robust timing belt/tensioner arrangements of all makes so they are quite suitable for these DIY methods. The 1.9TD tensioner for example looks like part of the running gear from a tank compared with a pressed tin and plastic tensioner from a Ford/Fiat/Vauxhall.
Many other makes of cars have very weak arrangements with procedure traps for those without proper tools/info.
David
David
alan s
- RIP 2010
- x 6
I see some strange set ups at times due in part to the business my son operates.
If you want a scarey moment, think about a Holden (early Nissan Skyline engine) that was here fitted with a single OHC that we converted to a DOHC head assembly off a Nissan GT-R.
Problems; where to fit extra tensioner(s) which belt profile, length and tension.
Must have got it right, because it was about 2 years ago it went into service and is still going.
I can always remember being told of the ways in which dealers service mechanics operated Seems testers; fit belt, fit tester. Set to recommended tension using tester as you go. On completeion check using thumb and forefinger and if tension doesn't feel right, adjust accordingly.
Which begs the question; are they really worth the trouble and cost?
Alan S
Alan S
RIP Sept 19th 2008.
- x 94
