My 306 Hdi has a an engine that refuses to fire. The tale starts about 2 weeks ago when it just stopped and refused to go any futher. The fuel pump in the tank was changed and it started first turn - Great. result
Its been OK since until today when it just refused to start, I checked the fuel supply as I thought maybe the pump I fitted had gone faulty but it seems ok as plenty of fuel is reaching the filter. Ive checked all the fuses but am now unsure how to proceed. Ive also pressed the engine cut out thingy. I dont want to take it to a dealers if I can help it. Any sugestions appreciated
John
306 Hdi wont start - Help
504
pugxpert
wont be air in a hdi. i would check your return pressure if to high will be much of a pressure drop between feed and return you need 0.8 bar diffrence to lift valve of its seat to allow fuel to enter high pressure pump. also try un plugging sensor on fuel rail as ecu needs to see 120 bar before it will start operating injectors if not enough high pressure disconnecting sensor will give ecu a default of around 400 bar if that does not work try tapping fuel pressure regulator on pump had a few sticking lets us know how you get on...
EP6T petrol turbo nice engine in the 207 GT and the new mini....
BK
Thanks for the replies. In the end I got a garage to tow it away to sort, as its to cold for me to work outside in the dark. The garage tells me that to much fuel is going back to the tank and its got two injectors sticking this seems strange to me as the car was running OK before it didnt start, why would 2 injectors fail at the same time? . Its all on hold now till the new year so I wil be spending Christmas thinking about the bill
steelcityuk
HDi engines have a reputation for destroying the injection pump when the lift pump fails. It's said by some to be because as the lift pump fails it sheds metal particles into the fuel which bypass the fuel filter (due to bad design) then mangle the injection pump. So resulting in a massive bill.
Have a read through this thread -
http://www.honestjohn.co.uk/forum/post/ ... tm?t=47331
Good luck.
Steve.
Good luck.
Steve.
not applicable
np
steelcityuk
BK
steelcityuk
Could you persuede the garage to use secondhand parts? If so -
http://cgi.ebay.co.uk/Peugeot-2-0-HDI-H ... dZViewItem
http://cgi.ebay.co.uk/citroen-peugeot-h ... dZViewItem
Steve.
Steve.
not applicable
np
I`ve been thinking about this filter housing problem,especally(?)the swarf thing messing up the pump.
How about these magnectic oil filter thingys,the ones that strap to the outside of the oil filter to catch any metal bits.
I wonder if they would fit onto the fuel filter housing to catch any swarf etc if the worst did happen.
53`406 est SE Hdi 140,110k
rotodiesel
np
rotodiesel
Hope you find a neat way to fit this filter. Remember, to avoid fuel waxing in the filter under cold conditions, you should ideally have the filter on the engine, under the noise reduction cover. Failing this, find the warmest spot you can and always run with Winter diesel when needed, never veg oil. A waxed filter element is an absolute b****r to clear.
Best of luck - I don't visit here often now as I bought the VAG as a towcar (damned good so far) but I miss the PSA "soul" - the VAG car is more like a well honed washing machine.
rotodiesel.
rotodiesel.
BK
I still havnt got the car back, they are still not sure what is wrong and are getting more test gear in and someone to use it.
How is the return pressure adjusted to give the .8bar pressure diff or is it preset and if so by what? I am not going to try and adjust it myself but I am curious about how it all works
BK
