hi
my 1996 1.9td xantia just passed another mot with flying colours.
when i am travelling between55 and 65 mph there is distinct whine/drumming, does anyone know what causes this and how to cure it, or at least reduce it
paco
Whine at55 to 65
AndersDK
Mandrake
- x 694
Wheel balance ?
Off round tyre ?
Wheel bearing ?
Regards,
Simon
Off round tyre ?
Wheel bearing ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 94
paco
jeremy
Sorry if some of these sound obvious but we've all been caught by them at times.
Gearbox oil - have you checked/topped it up recently? (Use the recommended stuff only - otherwise you may not be able to change gear.)
Engine/gearbox mounts - have a good look with thee engine running. Cambelt one may collapse if its like the BX/ZX one - seems to be a hollow rubber cylinder or something. (to be fair I've had 2 fail and never noticed anything) There should be 2 soft rubber wedges , one in front and one behind.
Gearbox is suspended from a mount on its top - usually well hidden. Is the rubber still there?
Engine bottom mount - can be seen from by the drivers door - does the engine wobble around and is it broken? - Have a look with the engine running.
Driveshafts? Feel all the joints for play and noise when the wheels are on lock.
jeremy
howzat
