BX Auto Selector Cable.
howzat
Unread post by howzat »
The auto trans selector cable on my BX16 (1991) has failed and is now unobtainable from citroen. Does anyone know if the cable from any other model (Zx, Xantia etc) can be used. Any help in finding an alternative source would be appreciated.
jeremy
Unread post by jeremy »
I have seen specialist cable makers - there may be one local to you.
Alternatively it may be that one of your local auto box specialists can help.
jeremy
philhoward
Unread post by philhoward »
Speedy cables in London claim to be able to make any cable, but will probably need the remains of the old one to get lengths etc and they may have to resuse the ends and/or the outer depending on how oddball it is. They're cheaper than you might think, apparently.
If you ask for an Auto cable for a BX, it's doubtful that they'll have a pattern and might need yours to make one.
alan s
RIP 2010
x 6
Unread post by alan s »
Can't speak for cable makers over there but here in the boondocks, we can buy custom made speedo cables for about A$25 less than the stealers ask.
The only problem I ever had getting anything like this made up was the clutch cable for the BX16V that has a counterweight fitted at the gearbox end. He didn't have nor could he get one and I wouldn't go without it as it was obviously there for a reason, apart from that about 48 hours including postage sees it done, but as has been said, it needs a specimen to work by. If it is in more than just 2 pieces, I'd reckon both ends and a length dimension would be all that they would require.
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
ekaftan
x 8
Re: BX Auto Selector Cable.
Unread post by ekaftan »
howzat wrote:The auto trans selector cable on my BX16 (1991) has failed and is now unobtainable from citroen. Does anyone know if the cable from any other model (Zx, Xantia etc) can be used. Any help in finding an alternative source would be appreciated.
A peugeot 405 one should fit. It may be longer or shorter, but both ends
are the same.
x 94
Unread post by citronut »
did you not get my pm to you as i said i have got a BX auto gear shift,mount and both the cables,i converted my first BX to manual from auto because i aquired it with a duff auto box,i think i also have the torque drive plate with starter ring gear
regards malcolm
howzat
Many thanks for all those useful suggestions, I am exploring the various solutions suggested.
