how long does a zx clutch cable last ?
zxb29
Unread post by zxb29 »
Hi all
how long does a zx clutch cable last?
my cars 1.9d jus about to hit 80k and was wondering should i be worried yet ?
thanks in advance
2005 ZX SX Diesel 64K
2004 ZX Aura TD 150k
2003 ZX Volcane TD 124k
swiss_steve
Unread post by swiss_steve »
Nope, you should be able to get double that before thinking about it. I've had two ZX's go beyond 200K and never changed the cable.
Of course, if it feels rough and can identify that it's the cable and not the clutch itself causing the problem, then I would do the whole job together. Also, with average use, a diesel clutch should last for over 120k.
Proud owner of two Citroens:-
'R' reg 1998 Xantia 1.9 TD Temptation Estate.
'N' reg 1996 ZX 1.9 TD Aura Estate.
x 94
Unread post by citronut »
if the clutch operation is very heavy this will strain the cable,i dont know if the ZX has the plastic clip at the pedle end of the cable like the xantias do,also if the pedle is heavy its usualy a sign the clutch is at or near the end of its life
regards malcolm
zxb29
ah phew thats a relief thanks for the info nothin to worry about for the next 30k at least
i think the clutch is ok just the pedal feels weird at times
