hi again,
all the lights work except the one behind the heating/ventilation/fan sliders and air con switch, they do flicker from time to time, so i guess there is a loose connection somewhere, i remember seeing the aircon one flicker more than the sliders ones,
does illumination to different parts of the dash/console come from different sources, as it's a bit of a coincidence that the one related to comfort are the dodgy ones, i bet it's all hidden behind the dash... in which case i may not bother, but maybe the case is that the sliders get the feed from the aircon switch? if so i may tackle it.
any info would be great,
thanks people
deian
p.s isn't it annoying that you can't lower the brightness of the radio display, it stands out too much for my liking when the rest are dimmer
slider/switch illumination question
Stempy
It's not too bad a job to get to the lamps in the heater control panel. Not much harder than taking out the radio.
There are two bulbs fitted to a lamp holder at the right hand side, one for the upper sliders and one for the lower. The switches have their own internal lamps and the switches themselves are fairly easy to pop out.
Dunno about the radio display, mine dims with the rest of them.
Lexia ponce
Lexia ponce
deian
no way? the radio bit really annoyes me, there maybe a missing wire in the connections somewhere
so basically i need to take the radio out and reach down to the left to check the bulbs?
the radio could do with refitting, it squeeks and rattles like no tomorrow, if i can sort that out too the car would be rattle and knock free.
davetd
Be careful taking out the double bulbholder!
It took me alot of manipulating and I had to move the sliders around a bit too to get it out.
Also if you take off the front slider display, you'll find the rubber strips keep falling out when you replace it.
Good luck though
davetd
Good luck though
davetd
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
