Fault Codes: Bosch Mono Jetronic A2.2
This is an ARCHIVE of common fixes. Material for this section should be submitted to an Admin or Moderator for approval then inclusion.
Guest
Unread post by Guest »
Monopoint injection fitted to AX 1.4, ZX 1.4
11 end of fault code output
12 start of fault code output
13 Air Intake temp sensor
14 Coolant temp sensor
21 Idle switch- Throttle Control motor
31 Lambda sensor signal
32 " "
33 Throttle position sensor
41 No engine RPM signal (crank sensor)
51 Lambda sensor signal
52 " "
53 Battery supply voltage to ECM
54 ECM failure
